bigmdm
5 Neutral
About bigmdm
  1. No. This is a plastic plate.
  2. This is the balancing loop and silicone hermetic.
  3. When I assembled this antenna the first time, I did not do the balancing loop. Those who collect this antenna for 3G band also do not recommend place the balancing loop.
  4. Ok. Please cutting the balancing loop and calculating again.
  5. I calculate for 2443 Mhz. (calculator)
  6. This is a experiment. I was build the passive retranslator for smartphone. It is a factory internal tablet wi-fi antenna. Experiment was not effective.
  7. I connect antenna from 50 ohm cable (10 cm) to a Android tablet. I no adapt this antenna to 50 ohm cable.
  8. An ordinary triple-square antenna gives tremendous results on the wi-fi band. I see about a 80 networks in an apartment building opposite (300m).
  9. Thank you! This is a very good work!
  10. I want to create a hybrid of the Turkina antenna and a 3-square antenna. Can you model it? I want to use two squares as vibrators, but they connect to the cable with a phase of 180 degrees. Is it possible to calculate the gain and the diagram of this antenna ?
