alansy
89 -
Everything posted by alansy
7 patch antenna I can't fix the whole topic, I only have photo reports, I can throw them into the 1800 topic, I didn’t like this antenna, the strip is bent from the temperature difference and changes the gap to the reflector and the signal level drops. 1 day works fine, the other stops. it is necessary to install a gap of 5 mm again
be healthy! good luck in business!
counted the sizes? when will you post it?
What characteristics of this antenna? connection lines how?
3 Kharchenko antennas at 530 MHz connected by a cable assembly; more than 800 MHz is not recommended to use cable matching.
maybe a little better!
OK! I thought you forgot.
Are the sizes of this antenna ready? can give? I want to do it.
I try not to go to his site at all. in order not to raise the site rating. he leaves links to his site everywhere. here I was arguing with him about this antenna.
is obtained? will we do this?
2 mm wire is available
I'm not in a hurry! just for information.
I can do this. I have 8 round patches for 90 mm, I can make the diameter smaller, I can solder the plates to them for powering. I can make another 90 mm, like 9 patches, I need a model of a good antenna, with dimensions and with a schedule for frequencies 1850-1765 MHz
OK! I'm not in a hurry, how is this option?
1 did not. Option 2 showed a good result. count the size of the strip
how is the antenna calculation?
I will wait for the antenna model with calculations.
I also thought about it, but I don't know much about antenna modeling. Really modem can recognize which antenna to download which upload?
