sridhar
About sridhar
  1. Hi Admin Can you please share the simulation result for 2.4 GHZ And exact dimention thanks
  2. Hi Admin Thanks please share the simulation results for 2442MHZ so it will be helpful to create antenna disk to extend my Wifi from broadband router to another building
  3. Hi Admin Thanks i will try the designing like given image the Gap between all 38 diameter disk is 20 mm or 22 mm????? 82 diameter disk- gap(5mm) ,74 diameter disk-gap (6mm),60 diameter disk -gap(10mm) 17 -elements 38 diameter disk gap is 20 mm right
  4. Hi Admin Thanks for the dimensions does the below dimension also work for 2.4 GHZ broadband internet extender? i saw this dimensions in first post so i have doubt whether to use above dimension or mentioned one
  5. Hi Admin Thanks i need to extend my wifi range to another opposite building so i need your suggestion which antenna i can build for extending 2.4GHZ,I Purchased metal sheet and thread and bolt need exact measurement to build 2.5GHZ antenna which extends broadband internet connection
  6. Hi Admin I have attached screenshot of my router details ,Archer C20 AC750 Wireless dual band router, i have enabled 2.4GZ wirelessband ,please suggest best long range wifi antenna DIY for better speed and better gain
  7. Hi Admin Accept my regards, Thank you for your help i have fiber optic internet connection modem has 2.4ghz WIFI enabled ,which antenna design will work for extending my internet to long range and high gain . could you please suggest DIY antenna design and measurement for extending my fiber optic internet connection please
  8. Hi Admin Does BDM-2 antenna will work for all wifi modem which has 2.4GHZ or only work as Mobile data internet network booster
