clanon
817 -
You use WHAT WORKS (that'll be DISCRETE PORT 1st and WAVE Port at the end) Same for Solver mesh settings
Face select inner+pet+shield+outer edge , then assign wave port (ALL of them should be leveled) puting a PORT on the END of an ANTENNA is a NO-NO
Still workin on it (good antennas BAD FEED NETWORKS !) I'll upload it if it works give me time After the simulation is OK on Port impedance Z (should be 50 ohms ) Electronics = Cables= Antennas (50Ohms=50Ohms=50ohms)
Those TWO collineal NEED an adapter to SHOW 100 Ohms in the middle (50ohms on coax) Two identical antennas of 50ohms would give 25ohms in the middle not right I ran one alone and is promising...
Those TWO collineal (2,4ghz) NEED an adapter to SHOW 100 Ohms in the middle (50ohms on coax) Two identical antennas of 50ohms would give 25ohms in the middle not right
First of ALL BOTH Your Coax cable HAVE NO SHIELD... Adding a SHIELD present a NEW problem (they would be DANGLING in the AIR -No Connected to ANYTHING)
Use THIS is more PRECISE (PS: also try rotating the tube gradually to get the POLARIZATION in the SWEET SPOT) Good work!
Yeah , that figures...it should have some impact on Simulation (as Ferrite FeO2)
BI CONE , central feed wide band (base is dielectric)
WAVY response Wide band..
THIS I SEE might be YOUR main problem...(Cut again to eliminate the bridging between CONES , it should be open and the disc is plastic)
Jomy do you have an stl file i'm interested on check it...?
Does it have two connectors...? Reactivity is high and Z should stay closer to 50 ohms... to be ideal...
