clanon
909 -
Everything posted by clanon
Still testing , Imepdance needs some work still...But looks good so far) Copper tape under 40 cm long and wide...PES foam or PU foam dielectric
Been beating around the bush for years to find a Good 4x4 patch array... Higher than 21 dbi , good impedance through the whole band,low enough vswr, under -20dbi side lobes... the original design is for 12,5 ghz and almost none side-lobes Power distribution Ratio 1:5:5:1 Changed it to WiFi , distribution ratio 1:1:1:1 (Original design Eliminated Sidelobes at the COST of 1,5-2dbi of gain) I'm happy (some testing still needed ) REAL dielectric constant of Polystyrene foam is a guess (1.02-1.05)
ONE of the TWO RED lines in the picture should be the same that the DISH to LNB support (one of those TWO red Lines should be ALIGNED with the dish LONG side height---
ALSO https://i.postimg.cc/pVs5WGZ3/IMG-20260221-142416012-HDR.jpg https://postimg.cc/z3RGpk4k You should get at least 2 or 3 db more if done correctly also S/N ratio gets better and quality of link (packets lost get lower)
depends on the PROVIDER Polarization if it's linear Vertical Horizontal at 90 degrees is ok...(if Circular you lose several DB) ussually is slanted -45 +45 (90) so rotating the feeder slightly you should get a little more or less gain
A disc without CUTS or SLOTS is Linearly Polarized...tho
A very well KNOWN DUAL band antenna 8dbi @2.4ghz 10dbi @5ghz You tube internals (Andrew)
88 db DAMN ! 2 Dipoles 6-9 dbi MAX by polarization 8.8 dbi
- 1 reply
POLITICS is gettin WEIRD all over...I'll use another host next time (my bad)
you are having issues on YOUR SIDE (DEVICE) my imgur picture is visible in MY post and also on YOURS...
Not so much...
if the connection is TOO BAD (75 ohms cable on wrong connectors , bad contact impedance high VSWR) it might be switchin to INTERNAL ANTENNA...hence 1-2 dbi gain
LTE Band 40 uses the 2300 MHz to 2400 MHz frequency range (FIRST the FREQUENCY then the BUILD around SUCH frequency) you seem to be getting NO SIGNAL 2 db is nothing
BRASS is great...Copper would be BETTER...(signal is LOST on small little defects on the way from Wireless card trough the antenna final contact point) CONTACT should be FIXED no play...
make sure there's GOOD electric contact between inner wire and Excited Disc (that White looks like polyester resin or some dielectric paint)
@yurik82 is it a BALUN...? looks like it..
is a link to your OWN site...
maybe something like this
I was hoping YOU have the drawings...i never draw any of those antennas...Is on the Petras and others a 3 strip balun from reflector to antenna...
Jomy , These BALUN details might be IMPORTANT to know (3-4 feeding STRIPS) do you have a drawing with Dimensions...(Russians use it all the time)
is built for bandwidth (i think)...discs won't get the same bandwidth...
good luck with THAT (Yagis hit a wall around 16dbi) more than 20 is a LOOOONG YAGI...and 200mhz bandwidth conflicts with gain...(A different antenna or a PARABOLIC DISH would get the gain , not the bandwidth)
Balanced vs Unbalanced
Dimensions are related to Lambda , it might be Full wave to work...like a Quad... did you try an Array...?
ALL BALANCED LOADS (electrically symmetric) Antennas , require a BALANCED Feed...since the use of a BALUN (which adds problems in itself , bandwidth is reduced , etc) Balanced load balanced feeding (Twin Lead or BALUN) UN Balanced Load UN Balanced feeding (COAX straight in)
