bejonet
Everything posted by bejonet
  1. my simulation antenna, it is will work or not?
  2. i have broken my omni TPLINK antenna, tried to reconnect the detached one, but the results were still unsatisfactory, what I should have done
  3. i have made biquad antenna for TV, reference at biquad calculator, frequensi from 470-800Mhz and place in indoor it is working good but not really good, a question is, there are way to tunning this antenna for best result..
  4. what affects these parameters, and what should be done??
  5. my bester antenna
  6. it is possible to create loco m2 antenna with 0.2mm metal sheet???
  7. and this is the dimension
  8. how to make triangle shapes in CST?? ,,,or from here...https://downloadly.ir/software/engineering-specialized/cst-studio-suite/
  9. The test passes through 6 walls, can still be connected, -80dBm, to open the router GUI very smoothly haven't had the chance to be connected to the internet, so don't know yet how much speed can be generated
  10. how about polarization of this antenna?
  11. it must using 0.5,,,1mm metal sheet??
  12. yes,, this antenna on the PCB
  13. hi Admin... you have detail for this model??
  14. attractive design
  15. it is true 16dBi ??
  16. try to make MiMo but is not good....
  17. yes, it has 90 degrees of wings, resize a reflector,, 460mm long and 117mm wide, with 16mm wings
  18. another achievement, and yes it work made from old CPU case, 0.7mm thickness cut by scissor
  19. I take it from here ... then change some parameters, just change the size and material and shape of the reflector
