alsamman80
3 Neutral
About alsamman80
  1. Strela 3G-4G 1700-2100Mhz..is it a dual band antenna (B1& B3) ? Thank you
  2. Hi, does this recalculated or design specially for 75 ohm cable? how much is the gain? Thank you.
  3. Hi Admin, Could you recalculate this antenna for 75 ohm cable? Thank you!
  4. Hi, does this work on 1800-2100 MHz (B3 & B1) frequency? Thank you!
  5. Hi Admin, How much the gain has the antenna in red? is it 1800-2100 MHz? Thank you.
  6. Thank you so much, what is the material, dimensions, thickness of the disks? The spacing between them? thickness of the body holding the whole assembly?
  7. Hi, I want to boost two bands B1 and B3. Can I make two antennas 1200 Mhz and 2100 Mhz and connect them one to the Main and other to DIV of my router? If I want to boost only the 1800Mhz band (B3), is the better to make two separate antennas or to make one antenna with two cables? Any wide range antenna 1800-2700 for 75 Ohm cable? Thank you so much
  8. Hi, any isolation applied somewhere?
  9. Hello Admin, Could you please send me all the details how to build by myself this antenna? I would need to know all the geometries in order to built it. Thank you
