35 -
and it's hard to believe about how good it perform
it's about my previous reply, the results is just the best for a small antenna. that's what I mean.
The result is out of this world!!! This access point is more than 4 km's away from here. using Tenda N301 as the radio.
Because those are the only materials available in my area, I don't know if it's worth making. yagi disc.cst
Oh, no wonder, using that wide reflector. this could be a great model for building my next antenna project. and by the way, thanks Admin!
Is it really 14 dBi?
erossutrisno started following Admin
n00bkali91 started following erossutrisno
I take the model from this topic and I change the materials to Al with some modification. antena_ns2 on Al.cst
What changes should I make to the antenna? (mechanically) when my simulation results are slightly higher off from the center of frequency. thanks.
erossutrisno started following PCB Panel Antenna
I did a simulation using FR4 as vibrator and 0.5 mm alluminium as reflector and the efficiency is just bad. maybe some modification on vibrator dimensions is needed. 14 dbi panel antenna 2.4 v1.5 R1.cst
erossutrisno started following Materials for construction...
How about stainless steel sir?, since it cheaper.
okay sir, I'm sorry
I wonder, is it possible to reduce the back reflector width to 120mm, and how bad is the impact if I do so.
Since I didn't have 150x200mm fr4, I made this with 100x200mm fr4, and it still working good
thank you sir!
Will this work on FR4?
