35 -
Everything posted by erossutrisno
and it's hard to believe about how good it perform
it's about my previous reply, the results is just the best for a small antenna. that's what I mean.
The result is out of this world!!! This access point is more than 4 km's away from here. using Tenda N301 as the radio.
Because those are the only materials available in my area, I don't know if it's worth making. yagi disc.cst
Oh, no wonder, using that wide reflector. this could be a great model for building my next antenna project. and by the way, thanks Admin!
Is it really 14 dBi?
I take the model from this topic and I change the materials to Al with some modification. antena_ns2 on Al.cst
What changes should I make to the antenna? (mechanically) when my simulation results are slightly higher off from the center of frequency. thanks.
I did a simulation using FR4 as vibrator and 0.5 mm alluminium as reflector and the efficiency is just bad. maybe some modification on vibrator dimensions is needed. 14 dbi panel antenna 2.4 v1.5 R1.cst
How about stainless steel sir?, since it cheaper.
okay sir, I'm sorry
I wonder, is it possible to reduce the back reflector width to 120mm, and how bad is the impact if I do so.
Since I didn't have 150x200mm fr4, I made this with 100x200mm fr4, and it still working good
thank you sir!
Will this work on FR4?
Aye aye, sir! thanks for the advise.
I would try to combine it in a strange way, without any deep knowledge of antennas. I don't know if this model can be improved any more. Not Simple patch antenna bare metal.cst
Well, it kind of not enough.
can I get dimensional details of this model sir? thanks
Well. at least I learn something for today.
I made this contraption, it works fine. 150m away from access point. Maybe just being lucky.
can I add "director" in front of the driven element? if yes, what dimension it should be? thanks
The problem is that file is not the exact dimension as the original, so I need help to somulate it.
Hi again Mr. Admin, can I get some help with this file?. Thanks. NC Link.pdf
Thank you Admin, even so I will still create one, just to practice making it
