marcosled86
2 Neutral
About marcosled86
  1. I know this is a 5 years old post, but i just made this antenna and works great, signal of reference went from 60% to 90% Used the files provided by elk user in https://www.lan23.ru/forum/node/81?t=67. 4.5mm from reflectpr to radiator and 200x200 reflector, thats what i got in had atm. i attached the files just un case. Regards 14db antenna.rar
  2. I just made this antenna and i can only say it works like a charm! and very easy to do.
  3. You awsome man, really apreciated.
  4. I mean. The dimension Will be the same?
  5. Can i make it with 0.5 galvanic sheet?
  6. the 8mm diameter can be changed to 3/8 inchs for the 25mm spacers? thats what i can get locally.
