DavidER
Everything posted by DavidER
  1. What is the distance for the connector?
  2. yagi
    And how many meters? 3,5,10?
  3. yagi
    Suitable except for cable 50 ohm 5d-fb, cable rg-316,174?
  4. Give an example of how to do this. Will it fit the antenna?
  5. And how to solder it? Adding copper wire?
  6. yagi
    Is soldering suitable instead of welding?
  7. yagi
    It was not possible to attach images. Therefore, I quote. A question for the administrator. Is this option suitable for antennas 1800, 2100? If you make a rim around the reflector.
  8. What kind of connector is this if the distance is 16mm?
  9. Did you conduct a simulation?
  10. The central contact is short. And if you need a longer length? Can't you build it up?
  11. yagi
    The topic is about 2400 antennas. And what is this desktop antenna that added a photo here?
  12. yagi
    For example, this antenna. It is connected to the USB adapter and to the computer. And what other options are there? Can I connect it to the phone?
  13. And it can be plugged into the socket where it's marked on the modem?
  14. And what is this pigtail with an antenna? What is it called?
  15. What are the antenna dimensions?
  16. Did you manage to model the antenna?
  17. Is it possible to add the number of drives per antenna?
  18. Can I add the number of disks to the antenna, up to 12-15? Will it also work?
  19. What specifically? It will not be difficult?
  20. In the modem, 1 nest under TS9 is broken. Then where can you solder the pygtele or cable?
  21. Is this pigtail suitable for ZTE MF920 modem? SMA - uFL/u.FL/IPX/ IPEX ?
