Alumni
About Alumni
  1. To shift the operating frequency upwards, you'll need to scale down the entire antenna geometry proportionally, since resonant frequency is inversely related to physical size. For your band: The center frequency shifts from ~2.2 GHz to ~3.55 GHz, which is ~1.6x higher. So, reduce all dimensions by a factor of ~1/1.6 ≈ 0.625. Your material choices (copper sheets/tubes or aluminum with proper mounting) are reasonable. Soldering for copper is perfect; for aluminum, ensure electrical continuity between parts, self-tapping screws or conductive paste with bolts can work
  2. If you add a reflector is still omnidirectional. An omnidirectional antenna is an antenna that radiates or receives radio waves equally well in all directions within a specific plane, typically the horizontal (azimuthal) plane. This means it provides 360-degree coverage around the antenna in that plane. To be accurate, in the response it could add 3 dB. Not 3 dBi. But we understand.
