Holmax
About Holmax
  1. Here is still found: http://www.lan23.ru/forum/showthread.php?t=9356
  2. Thank you. Questions: 1. Should the size of the insulator be the same? 2. If remove the "sides" of the reflector - greatly change the gain antenna ? 3. If take 2 mm wire? Greatly change the gain antenna? 4. Reflector - depth size (1 mm)?
  3. Hello. Do you have the dimensions for this antenna?
