Zhu_000
About Zhu_000
  1. i dont have ts9 connector its hard to find ts9 connector so i might as well solder the cable
  2. so it does not matter where i solder the wire on one of the two ? is it both 4g path?
  3. Hi ! i have huawei E5372s, image below im wondering where to solder antenna for the 4g connection as there is many option. 4G 1800-2400
  4. hi there im new here and i know nothing about antennas, i have few antennas that i can choose on the picture, if you guys can give me advice on which one i should choose for maximum dbi gain paired with 45 cm dish for 2100-24xx mhz based on your experience i would be grateful. i believe this is common antenna design right? but i really dont know anything about the frequency, so i dont know which one is correct. thanks. note : 75 ohm coax (RG6/U)
