Andrew77
49 -
13 GoodAbout Andrew77
Andrew77 started following Collinear antenna array
This one in picture
@admin Do you have cst or stl file of the cilindrical metal collinear antenna ? Many thanks!
Not perfect but seems working!
Here is, for CST 2019 Happy new year from Andrea Double_BiFilar_Helix_Antenna_UHF_4_sheet_Brass.cst
Hi, further improvements for the matching: check this
Andrew77 started following Bifilar helix (backfire)
Have you tried to get the GND closer to the antenna? VSWR gets better! In this case GND plate moved to the antenna by 6 mm
Yes, It Works! Have a nice day!
Hi Dear, Please could you send me the *.stp file? Because I'm using CST2019, Many thanks! Andrea
Andrew77 started following Bifilar Helix Antenna with Reflector
Andrew77 started following Petra-9 2x2 MIMO BOX antenna
Gain VS frequency? Thanks!
Andrew77 started following PETRA-12 MIMO USB BOX Antenna for 3G/4G
I already posed a question about this antenna, I made some simulations, have you succeded to simulate it?
mmm interesting, but seems lumped port, I don't understand well... Do you have this example in .cst format?
Sure, The antenna is not matched.. Here is just to check the settings... CST_Article138_RFID Reader-Coil, 13.56 MHz.pdf
I past it again... Simulation are same as mine Did you use Transient solver? if not what mesh? Your bounding box how big is? NFC_13_56_MHz.cst
here is the original antenna: NFC_13_56_MHz.cst
Hi dear,how are you? I made antenna by myself, I understand that corners must be rounded but I started with this version to have a simpler meshing... The version with rounded corners gives me quite the same inductance (around 1.24 uH) I'm looking for the examples inside CST (13.56 mhz coil ) but I have a big db file for examples in CST directory so I don't kown how access Andrea
