roman55524
17 -
Everything posted by roman55524
Friends, what sizes? I am going to repeat it soon.
Let's think about it. You can offer an irradiator with a gain of 3 dbi and a size of not more than 50x50? All Ubiquiti PowerBeam models have an irradiator with a gain of 3 dbi. Think they do not know how to do better? I want to use a reflector from this antenna and I need a small reflector to not close the useful size of the antenna. I will be happy with any of your ideas!
Will not close the useful area of the satellite dish (30 cm) this simple antenna? How much can it be reduced for 3 dbi?
any ideas ? need about 3 dbi
before these pins there is another small reflector of interesting shape
At me unfortunately the irradiator is not present. On the video you can see how it is arranged. https://www.ubnt.com/airmax/powerbeam-ac-gen2/
print on the printer, paste on sheet iron and cut
I suggest testing the design of this antenna. Jomy, I ask you to simulate the antenna. Impedance-50 Om Gain-9 dBi
I attach the file in the old format. Layout for carving mimo1800.vsd
I downloaded my file and opened it. Visio 2016
layout for carving mimo1800.vsdx
Than it is bad? Isolation between ports is available only for systems consisting of two antennas, each of which operates in a separate polarization
What can you say about the amplification on the edges of the LTE 1800 range in Russia? I have an assumption that this antenna has a bad outcome between ports.
error in reflector size ( 130mm
what is the distance between the first and second ports?
whether it is possible to make the recalculation on 1800 MHz?
will there be new correct sizes?
