Jayakumaran S
About Jayakumaran S
  1. sir iam designing a omni antenna in HFSS, should i include this spacer material or can i give gap(empty space)?, thanks in advance sir.
  2. sir what is that white coloured material between the copper tubes? and if that copper tube is hollow how it stand fit by means of that white material?
  3. sir i want slighty wider band(50MHz band width), i did array and metasurface , is there any other option to improve the gain sir.
  4. sir i need omni within 500mm length and having the gain of 12dbi what can i do sir, i did array and metasurface , is there any other option to improve the gain sir. Thank you sir for your consideration. thank you for your reply sir, please send any omni directional antenna source img or dwg files for improving the gain atleast 12-15dbi.
  5. Thanks sir, you are great man.
  6. so that i can get idea for my reqiured 340MHz antenna, tuning to 340MHz and i'll clear the doubt in port assigning.
  7. yes sir, i also need the dwg or design files, iam awaiting for your reply sir.
  8. thank you for your reply sir, please send any omni directional antenna source img or dwg files for improving the gain atleast 12-15dbi.
  9. sir, in our page wifi omni antenna is rare to find, can you fetch and share it with some dwg.files, please sir. thanks in advance.
  10. sir i want to improve the omnidirectional antenna at 340MHz with gain of 25-30dBi, is it possible? , can you send any design images or design files that match with my spec, please help me sir.
  11. Thanks sir, but i only know English, any site for English ? please sir
  12. dear sir, i knew HFSS, is there any site for HFSS like this ? please suggest me sir.
