dumser2
19 Good
About dumser2
  1. Not sure how and where to remove them?
  2. The question is, why is it that when I set the frequency from 0MHz to 2000MHz, the graph is one, and when from 0MHz to 3000MHz, it is completely different?
  3. Help me choose a 450MHz omnidirectional, compact FR4 or collinear antenna.
  4. Can you correct me because I don't quite understand what you're talking about?
  5. I made a mistake again. Please help. collinear_sma.cst
  6. Triple Feed Patch antenna https://www.maartenbaert.be/quadcopters/antennas/triple-feed-patch-antenna/ Triple Feed Patch antenna.cst
  7. I fixed it, it's much better.
  8. Can you help install them correctly?
  9. I made the Pagoda antenna from the dfx file, I'll give it to you in the article. But it doesn't work correctly. Where did I make a mistake or is it impossible to do it on FR4 https://www.maartenbaert.be/quadcopters/antennas/triple-feed-patch-antenna/ pagoda.cst
  10. Try to reproduce it, but here is my version, I have dimensions with almost the same parameters.
  11. Made in a hurry but it works, it could be improved but... Help me set it to 2.35Mhz
  12. Unfortunately, I already gave the antenna away.
