dumser2
Everything posted by dumser2
  1. I need your help, namely: calculations are needed Yagi-Disk antenna for 2350 with a band of at least 100MHz at 50Ω
  2. Help me choose a 450MHz omnidirectional, compact FR4 or collinear antenna.
  3. Not sure how and where to remove them?
  4. The question is, why is it that when I set the frequency from 0MHz to 2000MHz, the graph is one, and when from 0MHz to 3000MHz, it is completely different?
  5. Can you correct me because I don't quite understand what you're talking about?
  6. I made a mistake again. Please help. collinear_sma.cst
  7. Triple Feed Patch antenna https://www.maartenbaert.be/quadcopters/antennas/triple-feed-patch-antenna/ Triple Feed Patch antenna.cst
  8. I fixed it, it's much better.
  9. Can you help install them correctly?
  10. I made the Pagoda antenna from the dfx file, I'll give it to you in the article. But it doesn't work correctly. Where did I make a mistake or is it impossible to do it on FR4 https://www.maartenbaert.be/quadcopters/antennas/triple-feed-patch-antenna/ pagoda.cst
  11. Try to reproduce it, but here is my version, I have dimensions with almost the same parameters.
  12. Made in a hurry but it works, it could be improved but... Help me set it to 2.35Mhz
  13. Unfortunately, I already gave the antenna away.
  14. You can share your file on 2.4MHz frequency
  15. What needs to be changed to make it work at 2350MHz?
  16. Okay, but I need it for 2.35MHz. What is the diameter of the rings now? Yes, drop the file CST
  17. Yes, I didn't calculate the diameter correctly. I took the wavelength as the diameter, but I probably need the circumference.
  18. The diameter of the rings is 122mm, the platinum is 122mm, but it is FR4 without metallization. Required frequency 2.35GHz Biquad.cst
  19. Recommend an omnidirectional, circularly polarized antenna with a gain of more than 8 dBi Would this option be suitable?
