Henry
Everything posted by Henry
  1. The 3x Yagi loop was born.
  2. Hi, thanks for the suggestion, but I really only need a 3loop ant, max 1m long. Thank you.
  3. OK, interesting emitter design, ideal for Z setup. Please suggest for you an ideal 3 loop ant with max. G with dimensions with an ignition for both polarizations H+E as used on : https://oz1bxm.dk/sat/Wimo-70cm-Xquad.htm otherwise I will do the work. Thank you.
  4. OK, please what are the parameters of the ant with 3x 3x25mm tape and 3x 4mm wire? Thank you.
  5. I understand, bigger cross section bigger Q, but I need the ant to be light weight. I can't judge the difference in the parameters of the ants with a 4mm diameter and a 3x25mm strap. I have 4mm Al wire. Please what would be the differences? Thanks.
  6. Hi, that's perfect!! Sorry, I forgot, the wire loops have a diameter of 4mm. How would it be for only 3 loops? One last help please.Thank you very much.Henry.
  7. Hi, yes, thanks for the help, please max 3-4 loops.
  8. ... no magnetic ant, I need max 3-4 el.loop yagi. 10 el. yagi loop:
  9. Hi, I know, it's for the band HAM. It will be huge compared to wifi, hi. I will send photos after implementation. Thanks Henry
  10. Hi Admin, your yagi loop is very interesting. Could you please convert it to 144.2MHz? For 4 and 5 loop 4mm? Thank you in advance for your help. Henry
