devton
75 -
28 ExcellentAbout devton
>>2. Any suggestions for creating a robust hotspot with a 1km radius at the remote location? Use collinear TRUE 11....8dbi antenna for 2.4GHz in the center of area Like on picture attached to this post And then cover area stripe by stripe using sector antennas 5GHz Forget about entire 6 GHz band
3d-corner easy to build this antenna maybe hard to cut circles, maybe not... the Easyest way for you is to try to use your quados
Well, you can use your quados8 if you place it parallel to the ground and point exactly on base station 3x2 antenna from Admin...looks like it vertical polarization if placed as on picture it should have beam, cone radiation pattern not too wide 25 degree or something like that
and remember radiation pattern in this orientation - thin beam so u need to poin EXACTLY to base station, know exactly where it is, because:
to connect to base station u need antenna with vertical polarization so u should place it like that:
maybe it worked? did u checked your quados8 with SWR-meter? this antenna got horizontal polarization when placed vertical so it could not work with base station because of polarization missmatch -20...30db and if u rotate it 90degree, make parallel to the ground, it got ultra-thin radiation pattern so it is VERY hard to point it to basestation
hm...they got two 3.5dbi antennas X-pol... 3.5 x 3.5 = 12 (dbi) THIS is how this chinese antennas arithmetic woks
extender fo not so long distances
- 27 replies
- Wifi
- LongDistance
(and 1 more)
show us fotos or your fm reciever, please i think in your case there is some port\antenna missmatch and it is the only trouble on your way to ultra-long range FM-sessions
)) i think u do not need just "better things" i found this "Sven says this horizontal antenna receives stations 250–300 km away in northern Germany almost like locals" and if u got some troubles receiving stantions from 250km, it is most likely because it is 75 OHM antenna and your reciever input is most likely 36 o 50 ohms
addind 1-2 directors and re-emulating this FM5 looks like good idea
So THE best option 4 u is: Small FM5 Yagi because it is less than 3m, THE simplest construction, good F\B and tested for you requested distance: "Sven says this horizontal antenna receives stations 250–300 km away in northern Germany almost like locals" http://www.ham-radio.com/k6sti/five.htm it is so easy to produce. U can make your own and test it in couple hours
THE best FM-antenna is: FM5 YAGi https://3g-aerial.biz/fm5-small-antenna
only practice will show...but i still think: cable length from #3 on video and conection scheme from #1 is the best option
he is using 3 Different cable length in this antennas so IF you try to use cable length from #3 type (best SWR on video) AND use this cable length with connection option #1 it will be the best
