43 -
Everything posted by AmateurRadist
Hi! I had 2.4Ghz & 5-5.8GHz 14dbi panel antenna, I'm wondering if i want to have signle band antenna like only for 2.4Ghz and only 5.8GHz antenna - can i cut somewhere in middle and still have good vswr? Antenna made of galvanized steel, here is the drawings of it? I tried to cut right next to the soldering pin and assembled antenna but vswr was around 1.8-2.2 while factory vswr is 1.3-1.5 any help is appreciated thanks
Hi everyone, here i simulated 5.8GHz panel antenna in HFSS 2020R2, some results not showing correctly, what might be the problem? 58ghz_panel.aedt
i didn't noticed that, now it looks far better with your hints, regarding S11 parameter, in data report section there is no such, so is it calculated in HFSS with a formula? like s11 = gamma = (Z-Zo)/(Z+Zo)
@Docgi thank you very much for detailed answer, actually cylinders were plastic spacers, so i didn't assign any material, after your suggestion i deleted them. Now it looks far better, i'm wondering why half radiation goes backward eventhough there is ground plate, and how you check S11 parameter? in my "far field report" section there is no S11 Also vswr is very high, how i can lower it? thanks in advance 58ghz_new.aedt
@Docgi thanks, so i was getting some errors and i googled it and to solve it i had to click on "solve inside", it seems this created another error
@Admin I created GP and validation was ok, maybe somehow saved incorrectly or i don't know
aedt file link is under the photo
can someone hint me where i can get CST for free ot at reasonable price?
thanks, finally after some attempts it worked perfectly vswr <1.5, forgot to take photos
@clanon thanks yes with that filter added vswr was good, is there a filter for 5.8 too? To make 5.8 at least workable
After 10 failed attempts I think deviding was not good idea, so friends just use antenna as it is, hope above information will be useful to someone thanks
Yes it become just ordinary service recently, can you give some advices how to change lines?
I have at top corners, small square, can you help with that and check on simulation software?
You mean lines connecting elements?
Which limes?
I tried like this but still fail
Vswr is good why you think it is not good? I cut right next to solder pin and it showed good results like peak 1.8 at 2.3-2.5ghz with a good cable, but 5.8 didn't work yet
okay i will get dimensions asap
Most interesting part is that original factory antenna's vswr showing sometimes good vswr, sometimes bad depending on analyzer-antenna cable jumper's position, like if i bend it's good, i'm using jdsu celladvisor
I tried both options vswr still high, i placed feed1 a bit higher, to upper square though, it was originally designed with N type connector but i replaced it with cable, should it effect? i will try check sizes and send
have you seen dxf it's correct dimensions
here is the dxf file https://disk.yandex.ru/d/HBfm2j3BfYz5qA spacers are made of plastic, bottom 4mm, top 8mm
Any thoughts about this antenna
Thanks, I'll try, but I need a little time to remember. By the way, here on the forum I found material on using CST, also useful material. Could you also try to improve this antenna, anyway your experience is invaluable?!
So this is not original russian antenna? That's why we need to further simulations ?
