spark
2 Neutral
About spark
  1. And this How can use tow feed https://www.wifi-antennas.com/topic/141-wifilte-antenna-bdm-2/?do=findComment&comment=1283 and can i install two antennas to same modem
  2. Thanks admin but i think this is antenna not high gain as I would like . Well let me ask you about something In this antenna which is in the attachments Can I use two feeders Until I install it on 4G modem Is there a specific rule when I want to install 2feed for any antenna? I repeat my thanks to you, but the situation here is very bad because of the unjust war. I have to go out and go a long distance in order to get out of danger and use the Internet for a very short time. I will keep searching more
  3. (Line of SIGHT) .. I think it is good .h anks for your advice
  4. Can you give me this antenna for LTE 2300
  5. Can you give me design pleas
  6. Thank you for your answer . Ok can you give my desgin for high gain antenna multi band . #How FAR is the BASE antenna...city Kilometers. I think so 6 or 7 Kilometers .
  7. If you have pcb for band 40 LTE 2300 pleas give me the design . I think the pcb is easy . The problm with yagi antenna I think Yagi atennas are very interesting. And any sniper in the area will fire when trying to install itAny sniper in the area will shoot me .
  8. Can you give me like this antenna for LTE band 40 .. 2300 MHZ PLEAAS
  9. Hello, brother. Sorry I didn't explain. Dear I found several antennas For example, I found antennas of the frquency 1800. But I did not find any antennas for frquency 2300 in the forum . I could not find an antenna that supports both frequencies. Ok can you give me desgin for antenna for 2300 at less Sorry, my english is bad
  10. Hi pro Pleas I need desgin for antenna 4G But have high gain but without dish In my country, I cannot buy online because of the siege and war. I am in a border region and I need to receive the Internet from another country. And I need an antenna mimo high gain that can receive frequencies 1800 and 2100 Or multi bands . Can you help my give me desgin antenna like array patch panl or anther soultion . My respect . Sorry 1800 and 2300
