spark
11 -
Everything posted by spark
Hi pro Pleas I need desgin for antenna 4G But have high gain but without dish In my country, I cannot buy online because of the siege and war. I am in a border region and I need to receive the Internet from another country. And I need an antenna mimo high gain that can receive frequencies 1800 and 2100 Or multi bands . Can you help my give me desgin antenna like array patch panl or anther soultion . My respect . Sorry 1800 and 2300
And this How can use tow feed https://www.wifi-antennas.com/topic/141-wifilte-antenna-bdm-2/?do=findComment&comment=1283 and can i install two antennas to same modem
Thanks admin but i think this is antenna not high gain as I would like . Well let me ask you about something In this antenna which is in the attachments Can I use two feeders Until I install it on 4G modem Is there a specific rule when I want to install 2feed for any antenna? I repeat my thanks to you, but the situation here is very bad because of the unjust war. I have to go out and go a long distance in order to get out of danger and use the Internet for a very short time. I will keep searching more
(Line of SIGHT) .. I think it is good .h anks for your advice
Can you give me this antenna for LTE 2300
Can you give me design pleas
Thank you for your answer . Ok can you give my desgin for high gain antenna multi band . #How FAR is the BASE antenna...city Kilometers. I think so 6 or 7 Kilometers .
If you have pcb for band 40 LTE 2300 pleas give me the design . I think the pcb is easy . The problm with yagi antenna I think Yagi atennas are very interesting. And any sniper in the area will fire when trying to install itAny sniper in the area will shoot me .
Can you give me like this antenna for LTE band 40 .. 2300 MHZ PLEAAS
Hello, brother. Sorry I didn't explain. Dear I found several antennas For example, I found antennas of the frquency 1800. But I did not find any antennas for frquency 2300 in the forum . I could not find an antenna that supports both frequencies. Ok can you give me desgin for antenna for 2300 at less Sorry, my english is bad
