RC-Concepts
24 -
3 NeutralAbout RC-Concepts
Nice, it has a wide beam (Phi). Do you have the dimensions of it?
I tried your 45degrees, but I changed back to horizontal bow-tie. The reason for not using 45degrees is I got a wider horizontal beam with the horizontal bow-ties. For FPV, I need the horizontal beam to be as wide as possible.
Thanks for the tip. 45degrees will cover both vertical polarization and horizontal polarization too. I have changed the transmitting antennas to vertical polarization so I have all 4 Biquads positioned in vertical polarization (horizontal bow-tie) now. I did more range test in different urban evironments and here are the results:
I might buy it
Thank you for posting it for price comparison, I think it is a nice spectrum analyzer for hobbyist, and it has a good price too. It is a great tool for measuring S11 and S21 since it has dual ports. Although the spectrum analyzer sweep is terrible (non granular span steps and super slow), it is useful for tuning antennas for HDTV (UHF band), 2.4ghz(WiFi/BT/RC), 433mhz, 868mhz, 915mhz (telemetry/LRRC), 1.2ghz (FPV) and 1575mhz (GPS) because the inbuilt 3ghz Signal Generator and Signal Detector could measure the reflected co-efficient (plot SWR/ return loss curve) with adding the optional 9usd directional coupler.
You need to buy the 9usd SWR bridge ( directional coupler), to measure SWR on this device. Also, this device can only measure antennas for frequency less than 3ghz because it has a signal generator/tracker which is only up to 3000mhz. The 9usd SWR bridge also supports up to 3ghz only. The biquad we want to measure is 5.8ghz. Therefore, it cannot be compared to the Owl RC which has a 5.8ghz signal generator and a directional coupler that is designed for 5.8ghz.
105usd from Aliexpress
Yes the SWR meter can be DIY, if you see my video below, we can have RF switches controlled by Arduino to switch the video transmitter’s connection and the antenna’s connection to the directional coupler (without removing them physically), to measure FWD and REV voltages (output from the RF power detector) using the same Arduino and plot the SWR curve to a screen. As this is a lot of work, buying the SWR meter from Owl-RC is a better option.
Thanks, I haven’t tried maximum distance yet. In my video above, the drone was able to fly 300m away in the direction of my 9 o’clock when 2 biquads are pointing at my 11 o’clock and the other 2 are pointing at my 1 o’clock. This performance was pretty amazing. The SWR is built by Owl-RC and it is available here: http://www.owl-rc.com/product/SWRMETER.html
It is year 2020 now. And today we have digital HD FPV. Here I have built the same PCB 5.8g biquad and used it for the DJI digital FPV system. My feed points are slightly different and my center frequency is lower as a result. Test result appears promising in the video below:
Thanks for sharing this!
Alternatively, if the simulation software allows you to specify properties of the coaxial cable directly, the RG402 coaxial should have capacitance of 98.1 PF/m . Since our coaxial is 71mm long, the capacitance is 7PF. The capacitance (around 0.34PF) between signal (PCB A) and ground (PCB B) is necessary for the Pagoda.
I think you need to add PTFE tube of outer diameter 3mm and inner diameter of 0.9mm between PCB A and PCB C. This PTFE tube has a dielectric constant of 2.02 and a loss tangent of 0.00022
RG402 coaxial used for each antenna is 71mm. After PCB A and B are aligned, you mean VSWR is still 6.74 in your simulation? This is strange.
Great work! How about the radiation pattern and SWR curve after u solved it?
