pragata.my.id
Everything posted by pragata.my.id
  1. The router is WI-FI TENDA F3 (300Mbit / s). Type: Wireless Router. Standard 802.11 b / g / n. Interface connection (LAN port) 3x 10/100 Ethernet. Input (WAN-port) 1x 10/100 Ethernet. Connection via USB (external storage / printer / 3G-modem): no. Antenna: 3x5dBi. The number of antennas is 3-non-removable (Frequency 2.4Ghz). Coverage of wireless network up to 200 m².
  2. Patch Sectoral Antenna MiMo 14dbi.dxf Patch Sectoral Antenna MiMo 14dbi.CDR
  3. CPU Processor : Broadcom 300MHz Antenna Beamwidth : Horizontal: 60° Vertical: 30° Waterproof Level : IP64 Remote Web access : Support Schedule Reboot : Support Page Timeout : Support Dyndns : noip, dyndns.org Network Diagnoses : Ping, Traceroute, Signal Scan Dimension : 270*94.86*67.5mm Frequency : 2.4GHz Maximum wireless speed : 150Mbps Maximum Transmit Power : 800mw(29dbm) Reception Sensitivity : MCS0: -88dbm MCS7: -72dbm Maximum Concurrent Clients : 15 Interface : 1*FE PoE/WAN/LAN port 1*FE LAN Port Grounding Terminal : 1*RST Button 3G Access 12dbi Directional Antenna Maximum Power Consumption : 6W Lightning-proof : 4KV LED : PWR,Bridge,LAN,WAN/LAN Power Supply : PoE Injector (12v 1A,Cat5e or Better Ethernet Cable Length > 60 meters) Operating Mode AP/Station/Universal Repeater/Repeater/P2MP/WISP/Router Standard&Protocol IEEE 802.11n/g/b Features Enable/Disable Wireless Radio SSID Hidden Wireless Client isolation Sensitivity Threshold WMM Capable APSD Capable Wireless Access Control Wireless Client list Security 64/128 WEP,WPA-PSK,WPA2-PSK,WPA&WPA2-PSK,WPA,WPA2 Transmit Power : Adjustable power by 1dBm DHCP Server : Clients list VPN Pass-through : PPTP,L2TP Management Tool Time&Date Setting System Log Firmware update Backup/Restore Configuration Username Managerment Package Content O3Power Adapter PoE Injector Ethernet cable Quick Installation Guide Temperature Operating Temperature:-20℃ ~ 55 Storage Temperature:-40℃ ~ 70℃ Humidity Operating Humidity:10%~90% non-condensing Storage Humidity:10%~90% non-condensing
  4. What is the performance of such an antenna model, TDJ with Parabolic Reflector
  5. use copper wire?
  6. whether it can be applied to pcb?
  7. Can you put the dimensions on, sir?
  8. a/b/g/n/ac
  9. so, not all AC signals are MiMo, is that right?
  10. very simple, i like it..
  11. Omni, copper wire.
  12. satelite..? https://www.asiaa.sinica.edu.tw/gallery/show_c.php?i=6000290a34f57a75ec35ded48a8ab2c9
  13. Port1 horizontal port2 vertical
  14. for nice vertical polarization in the upper chanel, and for nice horizontal polarization in the bottom chanel, is that right?
  15. but great, can carry bandwidth of 20 Mbps at a distance of 4 km, with horizontal polarization, signal -65dbi to -70dbi depending on conditions in the field.
  16. Tenda o3 is bad when set to vertical polarization antenna
  17. sorry, I forgot to measure it, this device is installed, maybe 2 or 3 days I finish the data.
  18. simple
  19. means that the odd bait points on the edge?
  20. as always, I have seen, the number of elements if not one, two, four, eight. only this time I see there are three, maybe there are also five or seven.
  21. if odd, how is that radiation result? would not it be mismatched
  22. what is the result of impedance that is not good?
  23. and how do you make the connection between the element?
