Hamza
44 Excellent
4 Followers
About Hamza
  1. The. Easiest way to fix it. Is. To. Bend the cable
  2. The. Easiest way to fix it. Is. To. Bend the cable
  3. the direct connection of the cable to the feed point distorts the radiation pattern
  4. i love your work my friend its writen in blue the feed point 34 mm from the center the antenna is made for 75 ohm
  5. Greetings JOMY very excellent job. i m so curious to know the level of isolation of 2 ports (crossports) in your antenna design. being so busy i will post the dimensions as you asked
  6. VERY EXCELLENT its possible with MIMO feeding !!!!
  7. Greeting mister Jomy need help to make AXIAL (FRONTAL) FEED for parabolic dish ( no offset feed) for 1800 LTE MIMO 75OHM and thanks by advance
  8. DIY Frontal Feed MiMO system.For mobile communication B3 (1800) 4G LTE with good isolation of 2 ports preferably 75 Ohm
  9. VERY DANGEROUS WAY, BE CAREFUL ...!!!
  10. very bad response!!!!
