Hamza
Everything posted by Hamza
  1. DIY Frontal Feed MiMO system.For mobile communication B3 (1800) 4G LTE with good isolation of 2 ports preferably 75 Ohm
  2. The. Easiest way to fix it. Is. To. Bend the cable
  3. The. Easiest way to fix it. Is. To. Bend the cable
  4. the direct connection of the cable to the feed point distorts the radiation pattern
  5. i love your work my friend its writen in blue the feed point 34 mm from the center the antenna is made for 75 ohm
  6. Greetings JOMY very excellent job. i m so curious to know the level of isolation of 2 ports (crossports) in your antenna design. being so busy i will post the dimensions as you asked
  7. VERY EXCELLENT its possible with MIMO feeding !!!!
  8. Greeting mister Jomy need help to make AXIAL (FRONTAL) FEED for parabolic dish ( no offset feed) for 1800 LTE MIMO 75OHM and thanks by advance
  9. Windalo antenna need evaluation again and simulation it better than double biquad antenna .and some advice to make it ...
  10. VERY DANGEROUS WAY, BE CAREFUL ...!!!
  11. very bad response!!!!
  12. How about mimo system. The. Decoupling. Of. 2 ports 120 degree. Is it. Good. ? I want to see the s1s2. !!? Thanks by advance jomy
  13. thank you mister jomy u are absolutely right i tried without dielectic factor and does not work.!!
  14. Another repeater conception
  15. thanks jomy health for you i will use nylon bolt for support
  16. I want to try one for 75 ohm as repeater
  17. Interesting want to try. It. Jomy plz Wich modification are done ?
  18. isolator P.P Polypropylene (PP)2,2-2,4 Dielectric constant ε'
