103 -
30 ExcellentAbout lrg
3759 profile views
is it possible to improve?
4g booster for phone - YouTube
Can anyone make a smartphone stand? 4G Repeater for Phone Strength Test - YouTube
Petra-9 MIMO 4x4 Unibox-2L Universal panel antenna 8.5-10dBi (1.7-4.2 GHz) for modems with MIMO 4x4 technology support + Hermobox for modem + USB extension cable + Adapters
This is a feed for an offset dish.
The Nitsa-2F universal antenna is designed for use with cellular phones, modems or repeaters of the GSM900/GSM1800/UMTS900/UMTS2100 standards. The antenna type is a two-resonant vibrator with jet loops above the screen. To connect the Nitsa-2F antenna, we recommend using a cable Assembly (75 Ohm) Operating frequency range, MHz 890-960/1700-2200 Gain, dBi 9 / 9÷11 Bottom width in the H-plane, deg 70/50 Bottom width in the E-plane, deg 70/53 Input resistance, Ohms 50 SWR in the operating frequency range, no more than 1,5 Permissible power, W 20 Polarization vertical Mechanical characteristics Weight with mounting, g 835 Overall dimensions, m 0,2х0,2х0,045 Connector N-female The material of the radiator galvanized steel Protective box material ABS+polycarbonate
Нет. "Зенит"
