103 -
Everything posted by lrg
Petra-9 MIMO 4x4 Unibox-2L Universal panel antenna 8.5-10dBi (1.7-4.2 GHz) for modems with MIMO 4x4 technology support + Hermobox for modem + USB extension cable + Adapters
the desired size of the antenna. known frequency 1800 MHz cable 75 Ohm
Antenna Anteks Vika-24F MIMO General information Panel antenna Vika-24F MIMO is intended for use in complete equipment of wireless data transmission systems standards: 4G (LTE1800, LTE2600) 3G (UMTS 2100) 2G (GSM1800) WI-FI (IEEE 802.11 b, g, n) Electrical characteristics Operating frequency range, MHz 1700÷2700 Gain, dBi 2 x 21÷24 Width days, hail 8÷14 The sidelobe level, dB <-18 The ratio of forward/reverse, dB>20 Input impedance, Ohm 75 The CWS in the range of 3G/4G/WIFI, not more than 1.9 Isolation between ports, dB, More than 25÷30 Power handling, watts 10 Polarization Vertical + horizontal X-pol Mechanical antenna characteristics Weight with mount, g Overall dimensions, mm 800 x 800 x 540 Connectors 2 x F-female Antenna material Galvanized steel, aluminum The protective box material ABS+polycarbonate Operating temperature range -40 .... +60°C Standards support GSM900(2G), GSM1800(2G), UMTS900(3G), UMTS2100(3G), LTE800(4G), LTE850(4G), LTE1800(4G), LTE2600(4G) Operating frequency range 1700 — 2700 MHz Gain 24dB Gain range,21-24 dB Connectors for F-female Operating temperature range -40 .... +60°C Material galvanized sheet, steel, aluminum Material of protective polycarbonate Dimensions (length, width, height) 800 × 800 × 540 mm Weight 4760 g
AX-2600 OFFSET 75 Ohm MIMO 2x2 offset irradiator 4G. Operating frequency range, MHz 2500-2700 Own gain, dBi 9-10 the Resulting gain and beamwidth at-3dB level at different diameters offset parabolic antenna (at a frequency of 2000МГц) 0.55 m 21dBi . 0.6 m 22dBi . 0.9 m 25dBi . 1.3 m 29dBi . 1.5 m 30dBi.
Budget universal antenna Petra Lite Box c the dustproof and splashproof housing for 3G/4G USB modem. CRC9 connectors. F=1700-2700 MHz. GAIN=9dBi. Polarization X-pol. Standards: LTE-A, LTE1800, LTE2600, UMTS2100, WIFI.
Can anyone make a smartphone stand? 4G Repeater for Phone Strength Test - YouTube
is it possible to improve?
4g booster for phone - YouTube
Panel antenna MONA Unibox PRO with sealed box 3G/4G USB modem is the ready solution for signal amplification LTE800/GSM900/GSM1800/UMTS900/UMTS2100/WIFI2400/LTE2600. Electrical characteristics Operating frequency range, MHz790÷960/1700÷2700 Gain, dBi 8÷9/10÷15 Width of DN in the horizontal plane, deg 27÷68 Days width, in vertical plane, deg 26÷68 The ratio of forward/back, dB13÷20 The sidelobe level, dB<-13 Input impedance, Ohm50 SWR in the frequency range, not more1,8 Permissible power watts10 Polarization vertical+horizontal or X-pol Mechanical characteristics Weight with mount, g 2300 Overall dimensions, m 0,3x0,3x0,165 Internal dimensions sealed box, mm not less than 210x160x65Connectors 2 x SMA-male, USB, SIM Mthe material of the antennasteel, galvanized steel Material of protective box ABS+polycarbonate Working temperatures IP67 Mona_Unibox_Pro.pdf
The Nitsa-2F universal antenna is designed for use with cellular phones, modems or repeaters of the GSM900/GSM1800/UMTS900/UMTS2100 standards. The antenna type is a two-resonant vibrator with jet loops above the screen. To connect the Nitsa-2F antenna, we recommend using a cable Assembly (75 Ohm) Operating frequency range, MHz 890-960/1700-2200 Gain, dBi 9 / 9÷11 Bottom width in the H-plane, deg 70/50 Bottom width in the E-plane, deg 70/53 Input resistance, Ohms 50 SWR in the operating frequency range, no more than 1,5 Permissible power, W 20 Polarization vertical Mechanical characteristics Weight with mounting, g 835 Overall dimensions, m 0,2х0,2х0,045 Connector N-female The material of the radiator galvanized steel Protective box material ABS+polycarbonate
This is a feed for an offset dish.
Electrical characteristics of the Magnita-1 antenna Operating frequency range, MHz 790-960/1700÷2700 Gain factor (excluding cable losses when placing the antenna on the roof of the car), dBi 2÷4 / 6.0÷7.0 Gain factor (excluding cable losses when placing the antenna in free space), dBi 2,0÷3.0 Bottom width in the H-plane, deg 360 Bottom width in the E-plane at the level of -3 dB 15÷45 Angle of the main maximum position of the directional diagram when placing the antenna on the roof of the car, degrees 5÷25 Input resistance, Ohms 50 SWR in the operating frequency range, no more than 1,6 Permissible power, W 10 Polarization vertical Mechanical characteristics of the Magnita-1 antenna Weight with cable, g 240 Overall dimensions without cable, m 0.10 x 0.10 x 0.08 Attraction force of the magnetic system (at the thickness of the metal roof of the atomobile-0.7 mm), N 50÷55 Connector SMA-male / on-demand The material of the radiator tinned tinplate Casing material ABS + polycarbonate
Нет. "Зенит"
