afm22000
Everything posted by afm22000
  1. hi admin. is it possible to simulate in 4nec2 a 2.45ghz helix antenna inscribed on a pvc rain pipe? .. I read that I should use the frequency of 3620mhz, but also the relationship between turns is not altered? How do I adapt the impedance? Thanks a lot!!
  2. hi admin. do you have the reflector and spacing measurements? the pcb must be of some special type? Can you recommend any other antenna with similar performance using a pcb of less than 100x100mm? many thanks!
