Candyman
About Candyman
  1. Thank you Soo much.I will try and update Signal gain after this modding.
  2. Please some one elaborate on this topic... actually i was trying to attach external antenna but when i checked with Multimeter the point showing in the diagram to connect sma is ground ( negative) the sma legs should be soldered with ground but where should i can attach the main antenna line..please help me .The device showing in this diagram is same with mine.Thank you
