sandeepv
83 -
Everything posted by sandeepv
Hello everyone. can you please mention what type of materials and dimensions are used to form the cylinders in the below-attached pdf file. thank you 901_9850_customer_drawing.pdf 901_9850_3d_model_file.zip
Hello friends, I have designed a patch antenna shown in the attached file, I got the VSWR plot which is not identical to the one shown in the paper. How can I reproduce the exact graph in hfss. one more thing how can I plot the gain vs frequency plot given in the paper. cao2011.pdf test5.hfss
Hi friends, conformal antennas gaining a lot of attention from the researchers across the world nowadays. i will explain you the necessary steps required to design a conform antenna in hfss. Step1: First create a 2D rectangular sheet in HFSS with ranom dimensions step2. Create a cylinder with radius 30mm step3: Now select the two objects and perform the following commands-> right click->EDIT->surface->wrap shet. then assign thickness to the sheet
in order to get the circular polarization you can vary the two side arm lengths of the U slot.....there are pretty good papers in IEEE explaining the CP generation using U slot....but you wiull get narrow Axial ration bandwidth in such cases.....in order to get wider axial ration bandwidth go for slot antennas.
also try to watch these videos if you need further exposure. https://www.youtube.com/channel/UCdWKdDxPSzUgeOHQ9jf6zLQ
how to know whether it is LHCP or RHCP ?
PLease help me in this problem then i can complete my project report.
Actually that cpw line is optimized to give 50 ohm resistance.
I think we can plot the E field vector animation on the antennas excited by either port or port 4 in order to know whether they are working or not.
Dear jomy, kindly check S11,S22,S33,S44 plots also for me.
dear jomy .....can you kindly reproduce the result given in base paper for return loss
i have designed a mimo antenna in hfss,,,is it correct mimo.hfss
What about the radiation box jomy, should the radiation box enclose both antennas or not ?
suppose if i have a system like as shown in the below figure what should be radiation box size ?
I also needed design steps material to implement MIMO antenna system please provide the material for it also.
Jomy how can i design a receiver antenna to receive trasmitted power in hfss. I have designed two identical antennas one as trasmiter and other as receiver. i need design steps required to implement the above system can you provide it.
Is it dipole antenna ?
thank you jomy.... can u guide to design the same antenna in hfss. i have problem in making one antenna as receiver antenna and other as transmitter antenna.
ok....can please post the measurement result of the above antenna.. jomy could you implement the below cognitive radio antenna 2829357 (2).pdf
no jomy with sma connector i got good result 333.cst
please give comments on the below sma connector excited antenna 333.cst
please check the below file, i have designed the sma connector based on the above dimensions 333.cst
