Carlos
23 -
Everything posted by Carlos
looks easy to make
they have this template to pass to pcb
could you help me I want to make a 14dbi panel type wifi antenna I have the template and I went to ask them to make the figure and stick it on the copper plate and it does not give the measurements they know how I modify the pdf or images to the correct measurements it is the butterfly type and the path
- 34 replies
- 16dbi
- small size
(and 1 more)
you are right ami it affects me because of the trees that there are with the connection that I want to get use jn router wr480n tp link with a biquad of 31mm in one connector and its two 5 dbi antennas in the other connector
- 34 replies
- 16dbi
- small size
(and 1 more)
thanks I am going to modify maybe the error is in the antenna but I will also try to do the one recommended
- 34 replies
- 16dbi
- small size
(and 1 more)
Thank you very much for the help. If you know the subject, I think that biquad connlas went well for me, more than anything, it seems to me that stability will try to dialogue in English.
- 34 replies
- 16dbi
- small size
(and 1 more)
Bueno entiendo que estas antenas solo aumenta paea la señal que recibe y para enviar es diferente no la amplifica gracias por la ayuda
- 34 replies
- 16dbi
- small size
(and 1 more)
Gracias bros intentare crear esa antena la uso para conexion de unos 25 metros pero las antenas del wr840n son de 5 dbi
- 34 replies
- 16dbi
- small size
(and 1 more)
Esta antena fue la que cree pero no veo mejoria sera que esta solo funciona cono receptora por que no aumento la pontencia de la señal
- 34 replies
- 16dbi
- small size
(and 1 more)
- 34 replies
- 16dbi
- small size
(and 1 more)
Deverdad funciona ? Yo cree una para el router pero no veo mejoria
- 34 replies
- 16dbi
- small size
(and 1 more)
De la de 3 parches
- 34 replies
- 16dbi
- small size
(and 1 more)
De la de 3 parches
- 34 replies
- 16dbi
- small size
(and 1 more)
Que medidas?
- 34 replies
- 16dbi
- small size
(and 1 more)
Gracias hice la antena probare en 2.4g los parches van en cobre reflector no tiene esas medidas solo me falta poner y corto la antena
Que medidas utiliza en la ultima antena
