heinkel
5 Neutral
About heinkel
  1. Thank you Clanon.
  2. +3db You've doubled the profit, good design, Clanon. I can't open it because my CST is from 2012. Is there any possibility of backwards compatibility with the new CSTs?
  3. Awesome.
  4. Great.
  5. I was born in Argentina lives in Spain .I think you can improve the model's performance with CST. MerokaV1S11.cst
  6. I'm not from Spain, but I did meet Zero13 Wireless.
  7. The Meroka antenna's design is superior here only at 2.4 GHz. It features a resonant cavity with a monopole and director perfectly tuned to the resonant cavity, rejecting all noise signals. This makes it ideal for working in saturated environments.
  8. It looks like a copy of the Belgrano antenna, it has the same measurements. PLANOS ORIGINALES BELGRANO POR CHALENGER.pdf
  9. Awesome Super ¡¡¡¡¡¡¡ Thank you. ¡¡¡¡¡¡¡
  10. Really but is not a Windalo. Please can you remove the lobe ?
  11. Yes , you are right it is very difficult to try a simulation without the exact measurements. The antenna works very well if it is done as the creator indicates but he did not give the measurements for an exact simulation. I actually built it and it works very well despite that strange design.To simulate it you can use a little trick that is to scale it a little higher and lower and see if it is close to the specifications that gives you an idea of the benefits.
  12. What is a fake?
  13. Your simulation 15.4 not 11db
  14. Wrong simulation.
