Techd
About Techd
  1. my modem is single band 2.4ghz but I need someone who can tell me which antenna can give me 500mtr range if so plz suggest with measurements or dfx file for CNC cutting to achieve the perfect range and speed let me know
  2. 500 meter is free from obstruction that is open to air i can see the access point antenna without any tree or wall how can i achieve that range if i increase more number of directors can I achieve it in my modem there is two antennas that i can connect sould i have to build another wifi gun of same or sould i have to connect the 2nd antenna wire to same wifi gun at 90digree opposite of the right now connection shall i make two connections to same wifi gun and increase the more no of directors or build new wifi gun for the 2nd connection with the same no of directors in the 1st wifi gun kindly suggest your best configuration measurements to achieve that 500mtr target
  3. i was doing this project Wifi gun Measurements as per the pic .. Antena -2.png My Project : Antena-4.png Connections : Antena-3.png My Finished Antenna.. : Wifi Gun WP_20200807_23_27_09_Rich.jpg With this i am get wifi range of 100mtr but i am looking for 500mtr can you plz guide .. i asked many people in the forum but they dont give correct answer looking for your reply
  4. what should i do if i want to increase the wifi range for this antenna
  5. any wifi 2.4ghz antenna which has higer range cover for 1km and also has the speed because some wifi antenna have range but don't have speed even if the connected network has good wifi speed. i believe you will suggest me the best antenna with its cnc cutting detailed drawing for aluminium sheet so that i can extended my wifi signal and simultaneously receive same speed at the extended area. kindly help since last 2 days i am requesting you plz help
  6. do you have the measurement?
