Vasuki
Everything posted by Vasuki
  1. This is the model made by "ADMIN" 2.31ghz...... What is that number represents after coma , For eg- in the first disc from right its "37,8" Here 37 is diamerer of the circle . What does 8 represent ?? This is the rough plan i made before starting .... ,,,This is the rough plan before starting....... Is this correct Admin ? Can i know the thickness for the rod ?
  2. WHICH IS BEST,,,,,,WHICH WILL GIVE ME MORE SPEED , MORE SIGNAL STREANGHT (2310MHZ) ? 1ST OR 2ND ONE ?
  3. Thank you so much
  4. yagi
    What is this connector called ?
  5. yagi
    The second conductor should also be in contact with the modem ??
  6. yagi
    Thank you so much
  7. yagi
    Thank you so much
  8. yagi
    ,,,,,Here you have said " with the correct connector " will connector matter the quality of signal ?? !!!!! If so which connector and wire should i use for 2.3ghz antenna ?!!!!!
  9. yagi
    Okk i will try that one thank you.
  10. yagi
    this is the antenna i made for 2.4ghz (wifi antenna )
  11. yagi
    please send a diagram for 2300mhz frequency pls pls pls
