67 -
37 ExcellentAbout garry
2175 profile views
Happy New Year 2022 !, buddy, now you need a repeater, something like that, but consider the frequency at which 4G operates in your area. The repeater is required for this particular frequency. Callboost-gsm-2g-900-gsm.jpg .
- 9 replies
2
- 4G Repetear
- 4G Antenna
(and 2 more)
Buddy, if I were you, I bought a WI-fi modem with a module, for example, Huawei E8372. This will allow the smartphone to work on a 4G network, and work with voice calls over a WI-FI network
- 9 replies
- 4G Repetear
- 4G Antenna
(and 2 more)
I made this antenna that receives the signal from a distance of 14.8 kilometers. There is no direct visibility, there is high ground on the way.
Yes, my friend modem knows how to work with different antennas.
Yes, it will be a very interesting design. Does it contain MIMO ?
I think ALANSY needs two different antennas, one for 1855 MHz and one for 1760 MHz. These two antennas are connected to different connectors of the modem will increase the speed of communication.
On sale there are different versions of this model.I would like to clarify, version V3 has any restrictions in the system WiFislax?
Oh... as we want details......
I think the thickness of the material is not that critical. I used galvanized steel with thickness 0.2 mm for the vibrator and the Director, reflector in galvanized steel with thickness of 0.5 mm.
I have this design works well. Does the SMA connector match the connector on the router? If so, I don't know what can be changed.
Buddy... want details, if not difficult ?
My friend, please explain how to properly power this design. I don't understand at all.
Thanks, buddy...!!! This project, I think, will be interesting to all users of our forum!
If the matching lines are made of copper wire, it is quite possible.
This design is not difficult to repeat. Method to balance the four elements in future antenna I don't know.
