remio
Everything posted by remio
  1. I installed the batwing on the remote control with a slit vertically, on the copter the reception is also vertical, it turns out I need to redo and install the farting slot horizontally . Thank you clanon !
  2. If the Batwing emits horizontally polarized radiation in the horizontal plane, then how to position the antenna vertically or horizontally with the slit, if it is transmitting, and there is a dipole at the reception, which is now vertical, can the receiving dipole be placed horizontally more correctly?
  3. Hi, what would happen to the antenna at batwing 2.4 if the size of the reflector make 78h130mm ? I would like to insert 5.8 and 2.4 antennas into one case .
