Shabra
24 Excellent
About Shabra
  1. The result is better than ever.
  2. Thanks for advice. I'll try someday.
  3. Internet service provider that have a BTS(Base transceiver station) have to regenerated the sectoral antenna.If it have reached limit of usage will be changed with the new one antenna. And maybe someone use part of it(kathrein antenna) to get the signal. And becomes popular.
  4. On marketplace online platform In Indonesia like shopee,lazada,bukalapak,and tokopedia The seller get it from "flea market"
  5. Ok.I'm going to try it at fine weather.Tonight is rainy and little thunder at the sky and decrease the indicator of signal.
  6. I've build it. For indoor usage Distance from BS tower is 5 km And get the good result in 1.8,2.1,2.3 Ghz Thank's admin.
  7. Admin,I don't understand what you mean. May be you can explain to me something in a picture,please!
  8. Focus point grid antenna (60 x 90)cm is 31.25 cm Yes I have did it(reflector antenna vertical) and got more little result. Oneday I'll take photo of the detail.
  9. Focus point grid antenna (60 x 90)cm is 31.25 cm Yes I have did it(reflector antenna vertical) and got more little result. Oneday I'll take photo of the detail.
  10. How to crimp this junction? I've not found tutorial of making this joint.
  11. A part of ex BTS(Base Transceiver Station) antenna.
  12. Starting position like this, and surrounded by fox adhesive.
