noobbbb
14 -
4 NeutralAbout noobbbb
Dish dimensions 99/80, depth 9.5 . feeder rod 59 . but the degree of the rod is bend. from the calculator I saw that have to be 17 degrees. So I will fit it in position. Suggestions for feeders 2.4G and 5G?
- 8 replies
- or something else
- biquad
(and 3 more)
I have couple offset . there is no center feed I thing. for the diameter I will check tomorrow.
- 8 replies
- or something else
- biquad
(and 3 more)
Best Dish feader for 2.4Ghz and 5Ghz at one dish? bester × dual band cantenna × bat wings × biquad × or something else ×
- 8 replies
- or something else
- biquad
(and 3 more)
I just got the antenna. Next week I will have stubler to take the exact measurments and post it here.
I have ordered one of https://moonrakeronline.com/skyscan-desktop-25-2000mhz-scanner-antenna to see how it behaves. In the meantime there is cnc laser cutter that may accept commercial orders for some bat wings at the 2.4 and 5 (as dish feeder ) and also Wide Band Batwing Dual from the admin post. Otherwise the connectors are 100Khz-30Mhz and 25Mhz-17000Mhz. Also I am thinking to do some more bester if I get my hands on latte cuz the last time I did it with drill and sand paper to the exact measurements .... long long time do get there. On the to do list Bi-connical( looking for materials) and Inv-ammos. I will post the dimensions fot the skyscan if you like to make some simulations.
Okay, thank you!
yep, I remmember my brother burn his pcb's with some solution( I dont know the name of it on english "some kind of blue stone") but for 2-3 days and the copper layer was of and the left was what he draw with a permanent marker. I can try to print the pcb and repeat it with marker to the same measurments
yes some of those looks easier to make because I don't have laser cutter around. Maybe from pcb. If you have some suggestions for antenna to buy it also welcome.
cool, Thank you!
its for home use
the one I have ordered have no antennas at all. The seller use them for another project so I want to make some antennas for it. If possible to be broadband to cover as much of the freq as possible.
its similar to that one https://www.ebay.co.uk/itm/252473370203?hash=item3ac895e65b:g:UA0AAOSwRypZjTsx exept the chipset is RTL2832 & R820T. I catn't upload pics because I am waiting the dellivery today or tommorow and the seller have removed it. But as soon as I get it the screwdrivers will play and upload the real one that one is more like it hhttps://www.ebay.co.uk/itm/201773887159?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20201210111452%26meid%3D205512cc9f374948af29c314e28d4c02%26pid%3D101196%26rk%3D1%26rkt%3D8%26sd%3D252473370203%26itm%3D201773887159%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV2bAndUBSourceDemotionWithUltimatelyBoughtOfCoviewV1%26brand%3DUnbranded&_trksid=p2047675.c101196.m2219&amdata=cksum%3A201773887159205512cc9f374948af29c314e28d4c02|enc%3AAQAGAAACMOj9yveJBnYbHnaj9PwbsbAqVkIQWs%2FC5jogax5z8welyvuM60DeltUmLlTuAY42XXda7lEYcPp4CfE1LGj3JPJVjuMKzetEcIqbMDwY0AgR003LR%2FtjyKYdcjaecqQj3vvd5gOmNZfvyNNij%2BUjGfS9LIVMEcBTOzTlKtRfDSKreAjKPWzOOMLui4maCuD3EZkuYrmVY3PGKSJMwRuq5%2FIUppbUsCcd4fm4rkQdHlWzv%2BHa8y%2BUHJSekFxjz8RV1OnZV%2FUZSYfwhJieS%2FbWlVabSbgmBAUJjO1%2BVgBykRUsoma%2F7eCoKlmui6Ki8ojVYmr6WHuOH3cB3SlRt6qKqwJtKDdqDfMjxPtMhPASuFIyui5TUWmcPS1kAdUR8bULKg76rj1RmegBf3f7NWBy%2FijkXXEw9vQH881o0TLBE1pW45BZ8VsYfWDcjouJU93tVh1PLG6rKSDlqU2ja1eBUpP%2BQF49t7oZkZ7nHXHHIjKSl%2FX4xuhuT8eoCMznUJaV6tJfJKKpKCeMe0PdimKSuPZxUUAZNDFUF5VBE%2FntBg5kAETQyq0R3RlXWA4KNZ4Y4jCM2lRcu6D3zxSDaf0dKKHHOlq1kgwWsBbfdBFLwD3ullWQgORbhPXZ8C5yuRqNC1JmxDAYcbKtAWEiSWzoLqKFuup6tqIg12xor1CAbHH7sOxfBBGeFBdluvULFhtDFfaJN577nVeej9FTfcssohwCnZAzNR73HsGBhk9L9w4B|ampid%3APL_CLK|clp%3A2047675
Hey until now I was only watching and testing some antennas from here,( bester wich I extend a bit, quazi bow tie, biquad , double biquad and others, I didn't have the time to make the invAmos --all 2,4G) Now I get my hands on SDR and want to make some broadband antennas for it. It has 2 sma HF and UF 100khz to 1700Mhz. Do you have some suggestions for the toy?
