Rtyon
About Rtyon
  1. Yagi
    Hi I want to make a Yagi-Uda antenna for 2.4 ghz with straight Driven element (dipole) can I Weld the straight dipole directly to the SMA connector?
  2. would you recommend the best wireless adapter with high power and sensitivity for long range coverage and thanks in advance
  3. What is the range must be of the wire diameter in this picture
  4. I mean can I use the Gray hoverman antenna as wifi antenna without impedance I mean omit the impedance
  5. Will I install the omnidirectional antenna vertical or horizontal on the dish
  6. Yes I know how to insall the dish but cani use omni directional antenna to feed the dish
  7. it look like an antenna that exists on routers it's omnidirectional 5dbi can I use it as feeder on an offset parabolic dish 65 cm how to use vertical or horizontal
  8. IHi could I use an offset parabolic dish 65 cm with a coax collinear antenna 5dbi as a feeder how can I use the antenna vertical or horizontal I need more information about this and
