eco32
122 -
Everything posted by eco32
Ongoing
1296MHz disc Yagi-Uda is here
1296MHz => https://web.archive.org/web/20180619173254/http://www.dj6ep.de/HB9SSH/23cm.pdf , https://sq9mts.blogspot.com/2024/05/antena-krazkowa-hb9ssh-dj6ep.html 2,3GHz => https://www.ok2kkw.com/zzz/hb9ssh/hb9ssh_anteny.htm
Not eassy, but possible 165mm saw, => 160mm circle.
Update 917 x 720 welded iron bars (Pacific Grid) 917mmx720mm and 150mm deep f/d = 0.38 900 x 600 split die-cast magnesium f/d = TBD 600 x 400 split die-cast magnesium f/d = 0.35 400 x 300 split die-cast magnesium f/d = 0.38
In Australia, they have a strong tradition of using high-gain antennas, with versions available that are rarely seen. For starters, a factory 1300Mhz grid (I made one similar) and a 3.6HGz, in addition to the 2.4GHz 5.6GHz available in Europe. 900x600 Grids: 1.3 18dBi 2.4 GHz 24dBi 3.5 GHz 27dBi 5.6 GHz 868MHz GHz Antenna some feeds were explained here : "Siple Dipole" (which is no longer a simple dipole)
917 x 720 welded iron bars (Pacific Grid) 917mmx720mm and 150mm deep f/d = 0.38 900 x 600 split die-cast magnesium f/d = TBD 600 x 400 split die-cast magnesium f/d = TBD 400 x 300 split die-cast magnesium f/d = TBD I happen to have all sizes, i will update additionally something from Czech republic, not in production, but still available: Sito MMDS 175 AL http://www.satelit-tv.sk/obchod/sito-mmd...4502.xhtml Sito MMDS 175 cm kvalitne Hlinikove sito zložené z dvoch kusovParabolicke duralové sito, výška 175 cm, zisk 34dB, cena aj zo zadnym držiakom F/D = 0.41 34dBm
To know what to do ot not to do, It is not always possible to buy what you want. RND and learning
bacfire VS dish 1296MHz similar diameters, after long optimalisation in Matlab (end usage of thos tool soooooon)
may I ask, why 75 ohms, surely less copper in the transmission line and cheaper cost. Russian military antennas not knowing why, are all 75ohm?
Biloop by ua9yed in HFSS tool, almost 11dBi from https://www.lan23.ru/forum/node/885/page11 Here calculated on HFSS-11, the sizes took the same as you, only rings of copper cross-section 2.5 mm and the distance to the reflector 12 mm! In principle, and the results of the calculation are the same.I'll try to mess with coaxial feeding ..see what happens:mda: It turns out not big distortions of symmetry.Actually so it should be at such power supply.
- 7 replies
- double-loop two-loop
- biloop
(and 2 more)
I am thinking of using bi-loop instead of biquad, I use matlab on a daily basis, and I have not yet managed to make a model, I am currently unable to check 1) Bi-Loop is mechanically simpler to make, tune and correction. What else, what profit can it give. In publication about this antenna for a 2,45GHz: "The simulation results showed that the best parameters value are 14.95 mm of loops radius, 1.15 mm of links radius, and 15.57 mm of reflector gap. In these parameters, the antenna had a characteristic value of return loss -36.65 dB, bandwidth 354 MHz" IMG_1496.webp
- 7 replies
- biloop
(and 2 more)
I have no more excuses
I've had CST installed for over a year, just haven't had time to switch. How to get started? Colleagues, if you can help me get started, it will be full of benefit for everyone's in the community.
I can only use dipole with reflector with out circle and without ring in Matlab, i got 15,4dBi on this moment and optymalisation is in progress, Radius 47cm Heightt 21cm Spacing ~50cm freq 1296MHz
This ring works as a director or as a fresnel ring (assuming that this cross dipole is normally located in the cavity chamber)?
thats the andrew mcneil style: It is worth seeing what is inside, how it is made, while its conclusions and interpretations must be approached with great distance
What about dieletric as a microwave lens? It's probably the only chance to get more than 17dBi.
my observation from Backfire Antenna with dipole is more efficient than grid 900mmx600mm with dipole for 1296Mhz has 17.3dBi, smaller bacfire with diameter 57cm has also 17dBi and can be increased by adding fresnel ring to 22dBi (20 .... 21.05dBi in simulation). exemple how it may look like: (Yes, it is a dipole with coaxial splited balun and cavity)
@Admin "From R-409, on a common reflector two antennas, one larger 120-240 MHz gain 9 dB, four smaller 240-480 MHz gain 13 dB." "Two-element in-phase antenna array, zigzag emitters with a reflector (DB-11). Frequencies 120-240 and 390-429.8. Stood on R-415, R-419. Army VHF antenna DB-12 from the R-415 radio kit. Represents a broadband dipole. Dipole arms are 20 cm. Operating frequencies from 390 to 430 MHz."
It exist in R-415, R-419 manual, it is out of the google searchnig, i did not check Yandex.ru yet. It exist in paper version, some hams from my area has it, it is not eassy to get. It may comes from Radio Factory Omsk
"Two-element in-phase antenna array, zigzag radiators with a reflector (DB-11). Frequencies 120-240 and 390-429.8. Were on the R-415, R-419. Army VHF antenna DB-12 from the R-415 radio set. It is a broadband dipole. The dipole arms are 20 cm each. Operating frequencies from 390 to 430 MHz." VHF 120-20MHz in VHF 9dBi UHF 390-429.8Mhz in UHF 13dBi Gain of those version with grid is unknown
great DIY http://superkuh.com/shortbackfire-archerytarget.html
biquad or "double square" is also called "антенна Харченко" and searching for this name in google opens the gates of hell!
