efeksk
121 -
Everything posted by efeksk
It's been a long time. I was not active due to health problems. Now I'm slowly coming back. I have added a notch filter in the attached picture. This filter is produced so that the two RF systems working side by side do not interfere with each other. 1 watt rf transmitter in the 915 mhz band and 1200 mhz rf video receiver are used to avoid interference. This filter is to protect 1200mhz rf video receiver from noise from 915mhz rf transmitter. If this filter is not used, noise appears in the image. Should I do to build a pcb filter like this?
- 3 replies
- notch filter
- Notch
(and 1 more)
Hello my friends. I hope everything is okay. I hope you are healthy. I haven't been able to access the forum for a long time due to health reasons. I'm currently stuck with a j-pole design. Can we simulate this antenna according to the attached pictures? What will be the technical values of 3 different versions such as pattern, gain, swr?
What should the dimensions be for 868mhz?
I will produce one for you. And I will share all the measurements with you
Yes. But I don't know the actual gain of the antenna. And I don't have any technical data.
swr value is quite high. There are two ways to reduce this. The first is to move the feed point up or down. The second is to shorten it from the top wire.
aaa. okay okay. I get it now.
What did you misunderstand?
Understood. I also installed cst studio. I want to learn a little.
I need to be able to run this antenna at 868 mhz. But it must be highly profitable. 6 dbi 8 dbi 12 dbi How can I achieve these gains with 868 mhz?
Wow. You did a great job. does this test consist of 3 coils? So how is the test result with a single coil?
I know the dimensions. The data in the cst simulation that I'm curious about
868 MHz my brother
Bu programı kullanmayı öğrenmem gerekiyor. Nereden başlamalıyım? I need to learn to use this program. Where should I start?
Hello again, old friend. I hope I can be active all the time. The diameter of the wire used in the antenna is 1.2mm Coil inner diameter: 3mm Coil with 22 turns
It looks great. 2420 MHz and 5775 MHz. I can think of it as a metal with a laser. If you can give me the relevant files I can cut with metal laser cutting. Please tell me what materials I need to use
ooowww. yessssss
It must be pretty good. And the size should be max 12x12 cm
But it's pretty big
This is a great man
What would you recommend for 2.4GHz
