Simple Dipole Antenna
67 posts in this topic
 I don't really think so, it has to be checked...!!!
51 minutes ago, Dedewe said:
it is for 50 ohm for 75 ohms is there a size change mr...???
,,,yes...!!!
,,,which frequency.../?
i like to try do  such feed for a 1296MHZ, but I'm not sure about the dimensions, colleagues please tell me what would be the dimensions for a model with two reflectors. This one is too short, I modeled in matlab, resonance at 1500MHz (split coaxial balun):
Edited by eco32
Thank You!, please give me few days to build this, i will show You the result
I cannot find a commercial implementation of such an "feed"  also no publication with  "rear dipole feed with two reflectors". May the name is very specific, google does not return anything meaningful.
something about thos antenna from 1968
The Radio Amateur's V.H.F. Manual  - A Manual of Amateur Radio Communication on the Frequencies Above 50 Megacycles  1968
https://dokumen.pub/the-radio-amateurs-vhf-manual-a-manual-of-amateur-radio-communication-on-the-frequencies-above-50-megacycles-11th-ed.html
(I will try do my own for a 1296MHz)
From the description, it seems that it is not a "simple dipole" but a slot antenna.
,,,yes, it fits...!!!!
,,,and in the focus of an offset disc...
Diameters for a 1296MHz
     Hi, it looks very good!
Could You try diameters for a 1296MHz?
lambda      127.118644      lamda      231.481481
13cm(inch)      13cm(inch)      13cm(mm)      alfa      23cm
2+1/2      2.5      63.5      0.49953333      115.632716
11/64      0.171875      4.365625      0.03434292      7.94974923
1+1/4      1.25      31.75      0.24976667      57.816358
1+27/64      1.421875      36.115625      0.28410958      65.7661073
1+3/32      1.09375      27.78125      0.21854583      50.5893133
2+7/16      2.4375      61.9125      0.487045      112.741898
 3/16      0.1875      4.7625      0.037465      8.6724537
 15/16      0.9375      23.8125      0.187325      43.3622685
2+7/16      02-Jan      61.9125      0.487045      112.741898
,,,okay, I'll try to satisfy your desire...!!!
Thats grid with dipole rear feed with splited coaxial balun, basic version (1) with one reflector on the feed
Edited by eco32
,,,yes, it seems that this dipole with circular reflector is good....!!!
WOW! The antenna is very broadband! It Covers the entire 23cm band, this type of design is also suitable for LTE/5G
I have read that for grid parabolic antennas the reflector can be narrower, it does not have to be a circle, it can be a rectangle with rounded corners
With  my firs 13dBi design, I made the QSO with 250mW over a distance of 8km using the reflection of a tall office building. (I have different grids: 600mmx400mm 13dBi, 700mm x 900mm 17dBi)
Edited by eco32
Design with slot or with  coaxial splited balun - the reflector disc is smaller than the previous design, I guess that's the reason for the lower gain.
