bejonet
Panel antenna 12dBi
33 posts in this topic
my simulation antenna, it is will work or not?
Spoiler
Spoiler
Spoiler
,,, put the dimensions ... !!!
and this is Eric's picture...
This is an achievement of my Mexican friend, Julungas...
5 people like this
7 hours ago, Hamza said:
i think when the diameter 65.3 mm is better
,,,it must be tested... !!!
37 minutes ago, Hamza said:
Sorry monsieur Jomy that's what I found on the site .
,,,never mind...!!!
"Yes, Julungas is an old mexican friend of mine...!!!
1 hour ago, Hamza said:
you could put HINGES on the wings sides) for transportation...(make it portable)
,,, yes, hinges for adjusting the inclination of the wings between 17 ---- 33 degrees...!!!!
Yes 107 degree is the best   it took 1hours and half  to finish it   .thankfully I had already  2 disks 64.2 mm diameter. I got 57 % signal  with double biquad and 83 % signal with this Julungaz antenna. It's worth to Make.
.I got 57 % signal  with double biquad and 83 % signal with this Julungaz antenna.
so it's about 6 db more...(26% difference)
Yes  16 DBI estimated ...
1 hour ago, Admin said:
Great
Can i make it with 0.5 galvanic sheet?
