Panel antenna AX-2014P 2x2 MIMO- 2G/3G /4G
34 posts in this topic
Universal external antenna AX-2014P 2x2 MIMO is intended for use in complete equipment of wireless data transmission systems standards:
2G(EDGE, GPRS frequencies GSM1800)
3G (UMTS 2100)
4G (WIMAX, LTE1800, LTE2600)
Electrical characteristics
Operating frequency range, MHz 1700-2180
Gain, dBi 13-15
The width of the days in H-plane, degrees 30-45
Days width in E-plane, degrees 30-45
The sidelobe level, dB, not more -12
Isolation between channels, dB, not less 28
Input impedance, Ohm 50
SWR in the frequency range, not more 1,5
Permissible power watts 50
Polarization vertical+horizontal or slant +/-45 degrees
Weight with mount, g 1080
Overall dimensions without mounting, m 0,24х0,24х0,05
Connector- 2 x N-female
The material of the radiator -galvanized steel
Material of protective box-Polycarbonate+ABS
Operating temperature range-from -60°C to +80°C
Connector 2 x N-female
The material of the radiator galvanized steel
 Polycarbonate+ABS
Operating temperature range from -60°C to +80°C
-transmission line
-piece A
-piece B
Hello dear members of this very great forum, separate huge appreciation to Admin.
I'm wondering if anyone can help where is the second part round pair of cicrles.
By all the sudden, I started thinking about it when I got the two same details in hand and wondered how was I suppose to do soldering job here.
Any help is really appreciated
Best regards, Rizo
,,, good achievement, congratulations for AmateurRadist ...!!!
,,nothing is welded, bent at 90 degrees and then riveted with the riveter...!!!
PS
,, look once again, on my previous post...!!!
To say the truth, I got two same parts and somehow managed to solder(weld) them together and got this. However second connection's standing wave ratio is way higher, around 4-6.
,,, this is how the central connection point should look...!!!
,,, dude, you are missing piece B...!!!
Is it soldered by robots? I'm having hard time soldering this. I think this may be reason for high vswr. Also the machine didn't cut edges well, but I polished them to be ideally smooth. Hope next time it will work, it's almost cost of new one :) but I believe this experience is priceless :)
Edited by AmateurRadist
There is nothing solderd, yet there is bending at 90 gr and riveter..!!!
Sure I got this, I bended and riveted, then soldered the part with small hole to connector's pin. It's hard because there's so little space that soldering gun can't reach.
2) are there 4pieces cylinders over this? What's distance height from bottom they should be located? Will it have good gain without them also? If not what's their diameter?
Any help appreciated
Best regards, Rizo
 diameter=54mm at 8mm height
but you don't have piece B...!!!
I cut piece A and created piece B with welding parts :)
If spacers is plastic, is it okay?
,,,, preferably 0.5mm, but 0.25 ---- 0.8(1)mm can be used
The thickness does not matter much.
... for that...
it"s this adaptation lines...
how these cylinders should be placed, using 8mm metal or plastic spacer. And will it work without these 4 pcs cylinders
,,,, metalic  spacer...!!!
,,, will it work without these 4 pcs cylinders,,,, but the frequency band will narrow...!!!
for what frequency range it will be narrow.
31 minutes ago, Admin said:
1800-2600 MHz
,,, now I work on this ..!!!
How come? It's 1700-2200mhz, without cylinders will narrow to 1700-2600mhz?
2) these cylinders are not connected to main antenna in original version, why should I connect it to main part by metal spacer?
 I will try the simulation with and without the director cylinders..!!!
Greetings to radists
In second attempt/episode of "that looks easy, let's do it instead of buying" reality show I finally got 2.5 vswr max in main port and surprisingly amazing 1.8 vswr in second port without cylinders.
I suppose vswr in main port is high due to bad soldering, after bending it's like mission impossible to reach this pin. Before bending, soldering is easy but hard to bend.
I will try once more, are there any other things I need to consider to get lower vswr in main port i may be not keep in mind. Any suggestions are welcomed
Huge thanks to admin for his hints :)
However, this antenna is a good achievement...
", with the conclusion that these dimensions must be respected...
But it must be adjusted at 1800 MHz, if it's possible could you present CST file.
"For what this file, you can do simulations with CST...???
Yes, I once studied at the university on the subject of "antenna-feeder devices"
