Panel antenna AX-2014P 2x2 MIMO- 2G/3G /4G
34 posts in this topic
So this is not original russian antenna? That's why we need to further simulations ?
11 hours ago, Admin said:
"For what this file, you can do simulations with CST...???
"I think these dimensions need to be changed...
Thanks, I'll try, but I need a little time to remember. By the way, here on the forum I found material on using CST, also useful material. Could you also try to improve this antenna, anyway your experience is invaluable?!
,,, and yet, this is the real picture of adaptation...!!!
On 11/19/2019 at 7:45 AM, Admin said:
,,, good achievement, congratulations for AmateurRadist ...!!!
,,nothing is welded, bent at 90 degrees and then riveted with the riveter...!!!
PS
,, look once again, on my previous post...!!!
May i know what tools/equipment use to cut the work peace ... ?
Laser Cutting Machine
