ZETA MIMO BOX
Panel antenna MIMO ZETA BOX with a sealed box for USB 3G/4G modems is a ready solution for signal amplification LTE1800, UMTS2100, LTE2600, WIFI2400, GSM1800. Antenna type - common-mode grating of broadband vibrators. Recommended for use at the boundaries of the service areas, in low and unstable level of 4G/3G signal. Thanks to the use of a USB extension cable of cable of type FTP CAT5 is made possible to eliminate signal loss plot of antenna-modem.
Electrical characteristics
Operating frequency range, MHz 1700÷2700
The gain in the GSM1800 band, dBi 2 x 17.5÷18
The gain in the 3G range (1.9 to 2.2 GHz), dBi 2 x 18÷19
The gain in range of WIFI (2.4 GHz), dBi 2 x 19.5
The gain in the range of 4G (LTE), dBi 2 x 19,5÷20,0
The width of the days in H-plane, degrees-15÷26
Days width in E-plane, degrees-15÷26
The sidelobe level is not more;-12dB
The ratio of forward/backward, no less 20dB
Input impedance, Ohm 50
The CWS in the operating range, no more 1.5
Permissible power watts 10
Polarization - vertical/horizontal
Weight with mount, g 4480
Mount -mast with a diameter of 20÷52mm
Overall dimensions without mounting, m-0,45х0,45х0,06
Allowable wind speed, m/sec 20
Connector 2 x SMA-male
Material of protective box Polycarbonate+ABS
Antenna material and fastening galvanized steel
Protective coating -powder polymeric paint
