Bester Antenna
264 posts in this topic
,,, so do you want ... ???
Nice Great job , first time I see this design I mean other design jomy  with higher gain I ll try to find it
The  reflecter (130mm) DV (95mm) .first Direct ( 82mm)   2nd directer 56mm diameter and  ( 0- 7-8-39) of spacing like in BDM 2 1800 but the other directors are made of wire preferably with dielectric Boom if you can do optimisation in SISo system. Thanks by advance.
Edited by Hamza
1800
On 5/15/2019 at 8:44 PM, Admin said:
More gain;
Improved radiation pattern;
More stable operating parameters;
Greater reliability;
Superior mechanical characteristics.
Is miniaturized.
i try draw just got 7,7 dbi. i use copper disc and steel bolt.
can you corret me dude?
Edited by shosu.dsan@gmail.com
sorry we talk about 1800 BDM2 SISO  with wire directors ?!!!!!!!!!!!!! your model is already existed and discussed in the forum search well
the deformations are caused by the bar (rod) in the middle...using REAL METALS instead of PEC would give less gain and  efficiency
On 11/30/2016 at 6:18 PM, Admin said:
 Một ăng-ten 3G Bester ở tiêu điểm của phần bù parabol ...
A 3G Bester antenna at the focus of the parabolic offset...
On 5/7/2019 at 11:07 AM, Admin said:
,,,for this antenna, if there is put two directors again, you get a good one...!!!
Hi
What does happen if we isolate all discs from central rod (so isolate all from each other)? does it cause to increase gain or not?
Edited by bigbomber
11 hours ago, bigbomber said:
Hi
,,,it happens that the gain increases a little but it is about the protection against electric discharges...!!!!
on "THESE" getting more than 15dbi means using close to 20 directors...and EVEN then gain of yagis kinda HIT a maximum...maybe 16-17 dbi (Reflector AREA increase GAIN more than adding Directors) Use the BIGGER you can...imho
,,, a constructive variant of the user "com666" ... !!!
On 3/11/2019 at 10:25 PM, Admin said:
Диапазон LTE 2600 МГц.
4G antenna-LTE-абонентское устройство для улучшения приема сигналов операторами беспроводной передачи данных, работающими в 4G (LTE 2500-2700 МГц).
Greetings, jomi. We had such a dispute about which antenna is better to make, aluminum or copper. I would like to know your opinion!
I think the galvanized sheet is the best...!!!!
20 hours ago, Admin said:
Я думаю, что оцинкованный лист-это самое лучшее...!!!!
ok
,,, maybe so ...
On 12/1/2016 at 0:18 AM, Admin said:
 A 3G antenna Bester in the focus of a parabola offset...
It work in 4g lte+ 2300 mhz ???
I have trying this antenna in 2100 mhz... look good
but if I resizing gap is that any changes will be ? to get 2300 mhz?
,,, these are the dimensions(in Red) for 2.3 GHz...
Thanks...
I will update the result later
thank you for the advice.... the 2.3 GHz antenna is working good
Edited by khaiamin
,,, give up the nuts and put spacers from the 10mm diameter pipe and M8 screw inside...!!!
Put it inside bucket horn it works well ( I m HAMZA)
I put it inside bucket horn  it works so well.
